5-speed question
Old Sep 17, 2013 | 10:15 AM
vtraudt's Avatar
Originally Posted by Mike-2ptzero
B6 A4 1.8t 6 speed
3.667 (15.08)
2.053 (8.44)
1.37 (5.63)
1.032 (4.24)
0.8 (3.29)
0.658 (2.71)
Final drive ratio 4.111
Hmh.
Also found this info on B6 A4 1.8T 6 spd:
B6 1.8T 6 speed quatto: Overall ratio 6th: 2.5674
1st 3.67:1
2nd 2.05:1
3rd 1.42:1
4th 1.03:1
5th 0.80:1
6th 0.66:1
Final Drive 3.89:1
What IS the final drive of the B6 1.8T 6spd. 3.89 or 4.111 ??
Old Sep 17, 2013 | 07:11 PM
Mike-2ptzero's Avatar
Originally Posted by vtraudt
Hmh.
1st 3.67:1
2nd 2.05:1
3rd 1.42:1
4th 1.03:1
5th 0.80:1
6th 0.66:1
Final Drive 3.89:1
That is actually the gearing for the B7 A4 2.0T which has a 3.889 final drive. The B6 A4 1.8t had a 4.11.
BTW who ever did that list rounded up/down on the numbers.
Gear ratios (overall):
3.667 (14.26)
2.053 (7.98)
1.423 (5.53)
1.032 (4.01)
0.8 (3.11)
0.658 (2.56)
Final drive ratio 3.889
You are more then welcome to look up all of this stuff yourself.
Automobile-Catalog the complete Catalog of Cars, car specs database
Old Apr 18, 2016 | 10:34 PM
aaron.mallow1@gmail.com's Avatar
Default 1997 A4 2.8 gear ratio
That is correct. That would be high for a V6 or V8 but not high at all for a 4 cylinder.
Which is good gas mileage for driving those speeds.
Sorry to tell you this but a lower rpm at the same speed is not going to increase your gas mileage. The lower the rpm the less power your little 4 cyilinder is making while out of boost, this means to hold that same speed you would have to use more throttle which means more boost(less vacuum) which means more fuel is being sprayed into the engine. The larger displacement engines run at lower rpms because they are spinning more parts and feeding more cylinders with fuel. Just look at how bad the MPG is for the V6 cars including the 2.7t vs the 1.8t with its much higher rpm. Audi even listed the MPG for the B6 A4 1.8t 6 speed lower vs the B6 A4 1.8t 5 speed, only difference was the gearing.
The A4 5 speed does have shorter gearing, but that helps increase acceleration. Put a transmission with taller gearing and your car will just end up feeling even slower then it did with the stock transmission. I have already proved that at the track, 2.8 5 speed(taller gearing) vs 1.8t 5 speed (shorter gearing). With the 2.8 gear box the car went around 11.3 at high 120's, with the 1.8t gear box the car went 10.6 at 135+.
This is why I still run the stock 5 speed 3rd-5th gear, I put in slightly taller 1st/2nd gear out of a Audi Coupe 4.11 01A transmission.
Hey Mike_Audi do you happen to have the gear ratio for the 2.8 5 speed manual transmission?
pimphell
Sep 30, 2009 09:43 AM
banddr2
Sep 29, 2009 10:26 AM
itsnumb
May 22, 2007 11:57 AM
Dimad13
Sep 9, 2006 08:12 PM
BlackViper
Feb 21, 2006 01:22 PM
