6-Speed Shifting Issues
Old Jul 10, 2012 | 02:55 PM
MACattack's Avatar
Default 6-Speed Shifting Issues
Hi Everyone,
I recently picked up my first Audi Ultra Sport 1.8t, 6-Speed. It's very tuned... APR Stage +1, TT 225 Injectors & Valve, Carbon Cold Air Intake, and recently a DXD stage 1 endurance clutch & flywheel as well as some suspension stuff.
Here is what happened.. I got it with 56k miles and the clutch plate went out at 57,000.. so I got the DXD southbend because APR recommended it with my Chip. After the new clutch got installed, it shutters like crazy. Low RPM is so bad that my rear view mirror is shaking. Because of this, I run it between 2k-3k rpm - any lower and its a vibrator. It will shutter no matter what around 37 mph.
Recently, the shifting has been getting notchy. I started noticing some notchyness going from 2nd to 3rd gear. Are my Synchros going bad? Does the shift linkage need to be adjusted? was the dxd clutch not installed right?
Does the transmission need to be flushed?
Can someone help me figure out some adjustments I can make, so my car wont blow up?
Old Jul 20, 2012 | 10:35 AM
ppgoal's Avatar
I would guess the flywheel needed to be replaced along with the clutchplate. If the surfaces are not smooth, it would cause chattering and bad engagement. Based on the mods and the fact you needed a clutch, you could assume the PO had dumped the clutch plenty. Did they install a new pilot bearing when they replaced the clutch?
Old Jul 20, 2012 | 09:49 PM
rodhotter's Avatar
aside from other issues redline MT-90 makes shifting better than other fluids
Old Jul 21, 2012 | 11:32 AM
Audi Tek's Avatar
Tech Certified
If the clutch was replaced at 57k its because it was burned up..... most likely warped the flywheel
Old Jul 21, 2012 | 12:00 PM
MACattack's Avatar
No bearing was replaced. I did have a new flywheel installed. I think a lot of the shutter is from the fact that it's a single mass flywheel... Not dual. Southbend (apr) recommended it. Im worried that it's tough on the gear box.
MACattack's Avatar
Would MT-90 be better than AMSOIL?
Old Jul 22, 2012 | 11:08 AM
rodhotter's Avatar
Default redline va amsoil
i had used amsoil for my O2J tranny after the OEM fluid and was not pleased, car was shifting poorly i changed to mt-90 and was better and kept getting better, this tranny had 98,000 on it i used redline exclusively afterward until i traded at 199,XXXX miles, my TT with 6 spd had a little grinding going into 2nd, car had 37,xxx on it, a 2001 model,BEAUTIFUL black roadster, my first audi, anyhow after changing to mt-90 it shifts GREAT!!!
Old Dec 9, 2012 | 01:13 PM
rodhotter's Avatar
i had a single mass lightweight autotech steel flywheel with a VR6 clutch setup in my 1.8T 5 spd o2j shifted great!!
Old Jan 29, 2013 | 06:30 PM
bmay1984's Avatar
Default Mt-90?
I'm having the same difficulty shifting. Dealer said possible problem with 2nd & 3rd gear synchros. I don't know much about cars, but it seems like this MT-90 stuff may be a good idea for me... but what is it and how the heck do I get it into the car. lol any DIY links would be most appreciated.
Old Jan 30, 2013 | 06:53 AM
tofast2belast's Avatar
maybe its shuddering because of slippage. for the first few hundred miles the clutch may slip until its broken in.
