A4 3.0 Tip shudder/shimmy in drive or reverse
Old Oct 25, 2008 | 06:04 PM
Eric_C's Avatar
Default A4 3.0 Tip shudder/shimmy in drive or reverse
We picked up a B6 3.0 today. It has a shudder/shake in drive or reverse. Fine in neutral/park.
We knew this going into buying it but since it was such a good price I figured I'd fix it.
I was thinking converter but the car reacts perfectly. The MIL was not on, but then they left the lights on, killed the battery, jumped it and a MIL but figured that was from long/hard start after battery jump.
Didn't pull codes for some reason my VAGCOM will not talk to the engine controller. Can't clear the MIL, VAGCOM says I need a Pro cable.
Anyway to pull codes without a VAGCOM, any dash button combo?
Car drives fine but get a shimmy/shake severe at 60, and varying upto 85mph. Not trans/engine related since it does it in neutral.
Funny same issue as my A6 and another reason we picked it up since the problems were so similar.
Old Oct 26, 2008 | 11:09 PM
auditech79's Avatar
This is a FWD car i take it? You sure its not a CVT tranny?
Old Oct 27, 2008 | 04:49 PM
Eric_C's Avatar
Its a 3.0 Quattro tip.
After spending more time in it I'm starting to lean towards a mount or idle enrichment since the ECT is bad and needs to be replaced.
Old Oct 27, 2008 | 08:12 PM
auditech79's Avatar
Well since you can't pull the codes it makes it a PITA to diagnose, if the mounts have more than 80K on them go ahead and replace them while you wait for the correct vag com cable.
Old Oct 29, 2008 | 12:43 PM
widgget's Avatar
motor and tranny mounts first if you can't pull the codes.
saj01c
Jul 2, 2015 04:02 PM
saj01c
Jun 24, 2015 12:18 AM
rommellclarke
Sep 11, 2013 08:26 PM
mach1usmc
Sep 2, 2009 10:43 AM
night_rider
Jan 7, 2009 02:21 AM
