A4 Cranks, Hard Time Starting
Old Nov 15, 2013 | 06:51 PM
fordman's Avatar
Is the code gone?
Old Nov 19, 2013 | 04:44 PM
pa4ul's Avatar
in all honesty i would inspect all the wires going into the cam sensor. U might have a wire that is shorting causing this. I had that issue and had to replace the wires... was not too much fun
Old Nov 20, 2013 | 11:08 AM
fordman's Avatar
I have been thinking that for a few months now. While checking the wires it started idling properly...... any advice on replacement ???
Old Nov 21, 2013 | 04:06 PM
pa4ul's Avatar
i had mine cut and spliced but it was only frayed right at the connection to the sensor.
Old Jan 8, 2014 | 02:39 PM
Boystaysin's Avatar
Did you figure out what the problem was. I've had the same issue with mine, replaced cam sensor already and timing belt.
Old Jan 8, 2014 | 03:14 PM
tofast2belast's Avatar
do you get codes now? also, if its taking 30-40 seconds of intermittent cranking, it could be the the cam is off timing. i had this issue, it was off 1 tooth and would take a bit of cranking. but i got codes for intake cam advance setpoint not reached(cam over retarded)
if you want to check, take spark plugs out, set engine to cyl 1 TDC, remove valve cover and look at the chain side, on the exhaust and intake cam bridge, theres an arrow ^. count the number of chain links between the two marks. there should be 16.
Old Jan 8, 2014 | 06:31 PM
pa4ul's Avatar
thats exactly what was wrong with mine!
Old Jan 9, 2014 | 07:32 AM
  #18
mine too again sadly i think. now i get code that cam is over advanced
Old Mar 14, 2014 | 09:57 PM
  #19
rennick3's Avatar
Default Hard start 2003 a4 1.8
Hey guys,
First time on a forum and really hoping someone can help me out. I've got an '03 A4 Quattro with the 1.8t and yesterday out of the blue I had a really hard time getting it started. It usually starts first crank, no matter what the temperature. But the last couple days I've had to crank it 9-10 times for 3-5 seconds each time before it catches and starts, and when it does I need to hold it up around 2000rpm until it gets a bit of heat in it in order to idle. I've had a lot of work done to the car in the past year but am thinking it may be a MAF sensor?
Let me know,
Thanks
Dennisyudich
Nov 4, 2012 01:18 PM
mxindustry
Jul 20, 2012 01:33 PM
slacov
Jan 15, 2011 08:42 PM
montic
Sep 22, 2005 10:53 PM
