Airbag Light
Old Dec 22, 2009 | 10:19 AM
guru_king423's Avatar
Member
Default Airbag Light
for some strange reason my airbag light came one after listening to the radio in the car for a few minuets. Now every time i turn on the car the light wont shut off.....any idea how i can turn it off or what it might be.
Old Dec 22, 2009 | 12:00 PM
Dan1969's Avatar
Mine came off the other day and stayed on for a whole day, then it dissapeared, I didn't get a chance to scan it.
Old Dec 27, 2009 | 04:28 PM
mikeb's Avatar
Could be a loose connector under drivers seat.If so it can be tightened with a cable tie but the light will need to be cleared .Dont listen if you are advised to replace the airbag as I was by audi dealer.
Old Dec 28, 2009 | 12:20 AM
Dan1969's Avatar
You mean on the harness for the power seat? I'll check it out. Thanks.
Old Dec 29, 2009 | 05:46 AM
mikeb's Avatar
This is just for the bag not the seat. On my B5 there was a block connector under the seat which is known to work loose just enough to turn on the warning light.About 4 years ago my local garage turned off the light and advised securing the block with a cable tie and ignore audi dealers saying new bag needed .Itnever came on again I assume there is the same block on a B6 which i changed to in July but I have never checked so would like to know if this works for you
Old Dec 29, 2009 | 11:27 AM
dvmbound1977's Avatar
Mine has been on and off from time to time but never stays on. I think mine is the connector or a loose wire. Thanks for the location!
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
v8_ranch
Aug 27, 2012 12:45 AM
Niclipse
Apr 11, 2011 05:29 AM
geoff4
Feb 22, 2006 04:01 PM
