Audi A4 1.9 TDI replaced tandem pump- now no crank/start and no engine warning lights
Old Oct 15, 2018 | 12:35 PM
Thom Blaz's Avatar
Default Audi A4 1.9 TDI replaced tandem pump- now no crank/start and no engine warning lights
I have just finished replacing the tandem pump. On first start up the engine ran for a few seconds. Second attempt it turned over. Third attempt “brakes” warning light on dash. Since then none of the electrics on the car seem to work. No lights in dash etc.
when replacing pump I disconnected battery. I attached a jump starter in case battery was flat.
I’m quite new to this so I wondered if anyone had any pointers on what to check next. Is the next step buying a fault code reader? I must admit I didn’t bleed the fuel lines.
Cheers, Tom
Old Oct 19, 2018 | 01:00 PM
gsjohal's Avatar
So Im guessing it wouldnt crank over with a jump starter connected?
Does sound like a flat battery issue.
Bravo nice
Oct 24, 2016 09:46 AM
alpinebmuu
Jan 14, 2014 09:20 AM
jd.janson
Nov 17, 2013 04:37 PM
b.taplin
Apr 13, 2008 07:57 PM
JoeImp
Dec 18, 2007 04:08 PM
