B6 Performance ??'s
Old Mar 30, 2011 | 02:58 PM
606audi's Avatar
Default B6 Performance ??'s
What are you guys running for 0-60 times? Im not a big racer but i do want my car to be kind of quick. I was thinking about getting apr 1+ ecu tune. Anyone ever do this? Any other mods i should look into? Car is 03 1.8t
Old Mar 30, 2011 | 06:04 PM
pa4ul's Avatar
well if ur running stock a mini van would probably beat u. but with stage1+ u might get the mini van at the jump but he will pull on u once u get past 3rd.
Old Mar 31, 2011 | 05:46 PM
ppgoal's Avatar
A chip will make a big difference, but you have to accept that these cars are not quick. The weight and quattro work against off-the-line speed. But they are fast, once you get into the rpm powerband. Mine really takes off at ~3500 to red line, and is scary fast doing it in 2nd and 3rd. The other advantage of that chip is you will again blow by that minivan at 120. I would stick to 80-130 mph rolling start races and you should be ok. The chips also remove the electronic governor, so you can go beyond 133 mph.
Old Apr 1, 2011 | 08:11 AM
ImTheDevil's Avatar
Read the FAQ sticky in the B5 forum. Tons of info there and the majority of it translates to the B6.
brownstud08
Sep 3, 2008 07:00 PM
agunst9
Aug 26, 2008 07:50 PM
Wintermute
Sep 18, 2007 09:49 AM
audiant
Oct 18, 2006 10:43 AM
Quaberto
Sep 24, 2006 07:40 AM
