blinker stupidity
Old May 21, 2008 | 01:52 PM
zankey's Avatar
Default blinker stupidity
Just a quick question. My right blinker works fine and stays on when the lights are on but it won't blink when i turn on the turn signal whereas the side and rear lights will. The right blinker also blinks at a much faster rate than the left.
Any ideas? My thought is it might be a relay.
Old May 21, 2008 | 02:22 PM
TurboQuattroPwr's Avatar
Default RE: blinker stupidity
I thinks thats due to the blinker buld being bad or loose. Mine did it last week and I just smacked the housing and whala...it's fixed.
Old May 22, 2008 | 09:31 AM
zankey's Avatar
Well i got the bulb replaced so i doubt that it's gone bad. Besides, if it's loose, then why does it light up without fail when the lights are one but just won't blink.
Old May 22, 2008 | 02:01 PM
Audinick81's Avatar
The blinker bulb has 2 filaments in it. One that lights up with the headlights on and one that lights up when you turn the blinker on.
The blinker filament is either broken or the bulb has a bad connection (had one of those many times, caused by oxidation). Soremove the bulb, you'll be able to see if one of the filaments is broken or not, if it is not broken, then your contacts need to be cleaned
The blinker lights will blink faster when one or more bulbs burn out because the total amount of resistance decreases making the relay go faster
Old May 22, 2008 | 05:35 PM
auditech79's Avatar
If it acts up again, tap on the fender. If it magically works you need the electrical socket the bulb sits in, very common on the B6.
Old May 22, 2008 | 06:16 PM
AudiOso's Avatar
I had two of them go bad between my old 3.0 and my Avant in the space of a year. Yeah, they corrode, but good thing is they are only about $12 to replace and you just pop the headlamp out to change it. If you have a T-30 socket drive all you need is a regular 3/8" long extension and your rachet.
Old May 22, 2008 | 07:35 PM
Sublime865's Avatar
Might also be out of blinker fluid
lol
When one blinks really fast thats usually a sign of a bad bulb, have you pushed the little "Check" button that runs all the little on-car diagnostics? (lights, speedo, etc)
Old May 23, 2008 | 11:39 AM
zankey's Avatar
I think my best guess is that it's the socket that the bulb sits in because the bulb itself is only a month old. And i did clean off the contacts but had no luck. Where might be a good place to order the bulb socket and what is it called?
P.S. before i do anything i'll make sure to check the blinker fluid and re-oil my rotator splint.
Old May 23, 2008 | 01:20 PM
Sublime865's Avatar
Yeah, and while your there, give your air intake a good hose down with some dehydrated dihydrogen monoxide, regular dihydrogen monoxide is highly hazardous though, so be careful.
Wondering though, is that "check" button (right side below the speedo one of those 3 buttons) there for looks or does it actually "check" anything?
dragonrage
Feb 17, 2010 08:53 PM
kkgghh345
Aug 28, 2007 04:39 PM
juju4uofa
May 28, 2005 03:38 AM
