Boost leak
Old Mar 9, 2009 | 09:26 PM
kerNol's Avatar
Default Boost leak
So has anyone ever developed a boost leak on the factory charge pipe thats integrated into the lower rad mount. When pressure checking my charge pipes I could hear a slight hiss from under the rad but unable to completely pin point the location.
I also made sure it wasn't what I was hearing leaking down the cylinders into the oil pan.
Also what lines into the TIP should I possibly check for leaks as I'm currently having an issue pushing over 7psi, with or w/o the wastegate hooked up and n75 bypassed.
to4xxx
Jun 8, 2012 11:56 AM
onepoint8tee
Jun 27, 2007 04:38 PM
truckjunky87
Feb 8, 2007 12:33 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
a4bsix
Jul 6, 2006 04:28 PM
