Brake light, needs to be replaced?
Old Feb 7, 2010 | 12:33 AM
3dviz's Avatar
Default Brake light, needs to be replaced?
Have an 05' A4. Today when my lights came on I got the beep and the message that my right rear light was out. I parked the car and went around to check and it was out (middle of the 3). Later in the day I started my car again and got the beep and the message the light was out. However the 3rd time today when I went out to my car, pressed the unlock on my key remote, I saw the light was working again and when I started my engine I didn't get the error message. The 4th time, same thing, working fine. Anyone think this is a sign that the light is gonna need to be replaced soon, or something electrical or some sensor going bad?
Old Feb 7, 2010 | 11:29 AM
Dan1969's Avatar
Bulb probably loose. Check it out, you need to do it from the inside of the trunk.
Old Feb 8, 2010 | 11:32 AM
pa4ul's Avatar
x2^ Check to make sure its snug in their.
Old Feb 8, 2010 | 02:32 PM
3dviz's Avatar
Would I have to worry about a seal coming loose when I open the light up? I know with headlights, there are some seals to worry about as both of my headlights are fogged up from condensation.
Old Feb 9, 2010 | 12:30 PM
pa4ul's Avatar
The tails shouldnt be a concern. u should be able to just untwist the bulb from the housing.
RowdyAudi19
Apr 27, 2014 08:12 AM
PennSt8_A4
Nov 28, 2012 09:47 PM
Blackyk
Sep 14, 2011 06:42 PM
kwathom1
Jan 23, 2011 09:42 PM
MagicHobo
Nov 14, 2008 01:37 AM
