Brake Light problem
Old Jul 4, 2011 | 05:52 PM
mustangsailor's Avatar
Default Brake Light problem
Hi All!! New on the site and looking for some ideas.
I have an 04 A41.8T Quattro and recently have been having issues with my right brake light going out. It's very intermittent....sometimes it works fine and then just sitting there (like at a red light or stop sign) it will go out. Then later on the drive it may kick back in and work fine. I replaced the bulbs and cleaned the contacts, but that did not seem to help any. I checked over the wires that you can see near the tail light and they all seem intact and no signs of breakage. Any ideas as to what I could check next? It's only the right brake light....all other lights work as advertised.
Thanks for any light you can shed on the situation.
Old Jul 5, 2011 | 12:26 PM
pa4ul's Avatar
have u tried taking the light off and checking the actualy plug. Sometimes it gets loose and needs to be pushed in again.
Old Jul 5, 2011 | 05:12 PM
I did check that and I have also swapped bulbs from left to right to see if that helps. No luck. I am just hoping that I can figure this out and that it doesn't turn into a big bill down the line.
Old Jul 12, 2011 | 08:58 AM
byrnedave's Avatar
Try changing the brake switch.
Old Dec 29, 2011 | 01:08 AM
Tims Toy's Avatar
I had a similar issue with my LH Brake light and did a resistance check from one brake light bulb to the other brake light bulb and found the metal run on the assembly that provides the power and ground to the bulbs was the issue. For me it was the power side that had the issue.
Tripin
Apr 12, 2013 10:15 PM
luciddream42186
Jan 25, 2012 08:13 PM
ziggy64
Mar 10, 2011 09:13 AM
peterbr1717
Aug 13, 2010 03:28 PM
smoovmusicdj
Aug 22, 2007 10:27 AM
