Brake Pad Wear Indicator
Old Sep 13, 2010 | 02:36 PM
domnf15's Avatar
Default Brake Pad Wear Indicator
Hi All,
This is a fairly basic question so hope I'm posting in the correct forum -
2005 Audi A4 1.8TQM - my brake pads (front and rear, I believe) appear to have the wire coming out of them that gets attached to some sensor. My question is, when the pads wear down sufficiently, will I get some idiot light/dash warning message? Or are these wires simply to tell the ABS computer how it should apply brake pressure based on remaining pad thickness? Do the pads also "squeal" when they are worn down to the point of needing replacement?
Old Sep 13, 2010 | 08:03 PM
AudiS's Avatar
Your breaks can squeal at anytime, as for your other questions I cant answer them as Iam new.
Old Sep 14, 2010 | 12:22 PM
pa4ul's Avatar
it will tell u when they are running low.
Old Sep 14, 2010 | 06:26 PM
ppgoal's Avatar
I could be wrong, but I was told my A6 and my 2003 A4 3.0 MT6 only have brake wear sensors on the front pads. Nothing on the rears. Squealing could be dirt, rust, or (worse) your pads are down to the rivets and ripping into the rotors. My Crossfires (SLK320 running gear) are also front sensors only.
hartsoe1
Aug 26, 2013 05:08 PM
hartsoe1
Apr 29, 2013 09:13 AM
yenkonova
Mar 21, 2009 02:50 PM
eliTTe
Jun 8, 2007 02:08 PM
TT225R
Oct 6, 2006 07:44 PM
