Central Locking with key / Altering with VAG COM
Does anyone know if it is possible to unlock all doors with key?
My car only unlocks drivers door with key then when you put key in ignition it then unlocks the other doors. The remote is not working at moment so have to use key.
I was wondering if it can be changed on Vag Com? Been looking into it but can only see things that affect the remote fob not the key itself. Bit annoying having to turn ignition on to unlock other doors
Thanks
Alan
Thanks
Alan
What about the lock/unlock switch above the window switch on the door? I know it's not quite what you want, but it should operate w/o having to turn the car on. Also, have you put a new battery in the remote? I would imagine that a dead battery is the most common reason they stop working, and it's a pretty common battery (CR2032, should only cost you a few dollars at most).
