Cold air intake?
Old Aug 23, 2011 | 05:25 PM
Slade's Avatar
Question Cold air intake?
Im thinking about getting the Audi A4 (B6) 1.8T Carbon Fiber Cold Air Intake System any advice or any other intakes u would perfer?
-thanks
Old Aug 23, 2011 | 06:02 PM
pa4ul's Avatar
honestly ur best bet is to get a drop in k&n filter or those blue filters. and just stick with the stock airbox. It provides a sufficent amount of air to the powerplant. If u want to achieve more sound out of your turbo u can pull the airbox out and take out all the sounddeadening material and that will increase the noise level of the turbo.
Old Aug 23, 2011 | 08:05 PM
Pootus's Avatar
what do you mean more turbo noise? like hearing it spool??
Old Aug 23, 2011 | 08:55 PM
Slade's Avatar
can i pull the sound deading without replacing the stock intake?
Old Aug 23, 2011 | 09:18 PM
4rings4life's Avatar
Default My advice
i just put the carbonio on my B6 1.8T and not saying that its a bad unit, but after i installed it i dont care for it. it does make allow you to hear your turbo spool up but the part that i dont like is that when you release off the gas you hear a noise thats verry simular to a BOV and to me it sounds like a Japanise car. so my next audi i wont do an intake. if you can try to find someone in your area that has one on a turbo audi/vw b4 u buy to see if u like it.
Old Aug 23, 2011 | 09:32 PM
Slade's Avatar
[QUOTE=4rings4life;1330558]it sounds like a Japanise car.QUOTE] what do u mean by that and how long have u had this intake? and any others u would suggest?
-thanks
Old Aug 24, 2011 | 11:44 AM
pa4ul's Avatar
yes turbo spool. And the sound deadening material is inside the airbox where the filter goes. 4rings4life are u still on the stock dv or u aftermarket.
Old Aug 24, 2011 | 04:25 PM
Slade's Avatar
so to remove the sound deading im guessing i have to take out the intake which i can do and then what?
Old Aug 24, 2011 | 06:12 PM
pa4ul's Avatar
just strip out the sound deadening material that is inside the airbox go buy a k&n filter or whatever highflow filter of ur choosing and thats bout it. Just drop it in and ur good to go
Old Aug 24, 2011 | 09:35 PM
Slade's Avatar
is there a k&n filter u would perfer? or other?
