coolant flush
Old Jun 8, 2008 | 03:08 PM
blackphoenix's Avatar
Default coolant flush
so, i looked for this red valve everyone talks about to flush out the coolant, i can'tfind it. i took off the front grill vents and searched.. still can't find it.. what is the easiest way to flush out the coolant, or find this valve thingy. thanks
Old Jun 8, 2008 | 03:39 PM
cincyTT's Avatar
I'm make believe
Default RE: coolant flush
There should be a valve attached to the bottom of the radiator (usually behind and you have to get under the car to find)that you just pull then turn the **** to drain (make sure the filler cap is open also). Then run a couple gallons of distilled water through to help flush any remaining coolant out and then refill with the fresh G12 and more distill water.
Old Jun 9, 2008 | 10:15 PM
monkey323i's Avatar
If you look through your manual,
it stated audi OEM coolant from factory is permanent, which means does not need to be changed lifetime.
Old Dec 31, 2009 | 07:12 AM
heywier427's Avatar
good luck with that one...
Cullen
Jul 14, 2012 10:29 PM
Armenian
Aug 31, 2010 04:18 PM
dark knight
May 5, 2009 02:12 PM
ConMan
Feb 16, 2009 02:30 PM
mrdb85
Oct 20, 2006 03:26 AM
