Coolant and fuel gauge problems.
Old Apr 29, 2011 | 01:35 AM
bmenji84's Avatar
Default Coolant and fuel gauge problems.
Hi everyone,
So I just purchased my '04 a4 1.8t. When I got the car I thought that it had a full tank of gas as the needle passes the full mark to the actual little gas symbol. It has been 2 days now and it does not move. What is wrong?? Is there another way for me to check my actual gas left?? Also I was driving all day and it was fine, but when I started driving uphill in the freeway, the temperature needle whent to the 3/4 hot mark and my coolant level light started to blink and make noise. When I parked I checked the coolant level and it was between the max/low so im assuming it's fine. Any Ideas on either issue?? Thanks
Old Apr 29, 2011 | 07:14 AM
Dan1969's Avatar
If it has over 80k miles on it the water pump and timing belt might need replacing. Check with whoever you bought the car from. As far as the fuel gauge, your fuel sender might be kaput, fairly simple to replace.
Old Apr 29, 2011 | 09:29 PM
gabby456789's Avatar
If you do a timing belt/water pump change, check out my post on tips for a timing belt/water pump change on 2003 Audi A4. On 03 and above, they changed some things and other threads don't address these.
Old Apr 29, 2011 | 09:31 PM
Old Apr 30, 2011 | 02:23 AM
bmenji84's Avatar
Cool Thanks for the info. Very helpfull.
Old Apr 30, 2011 | 04:26 PM
bmenji84's Avatar
Does anyone know if my gas light will come when tank is almost empty?? I mean since my gauge is not working. I dont want to be on freeway and have car shut down.
Old May 2, 2011 | 10:42 PM
Dan1969's Avatar
Light will come on and beep when you're low on petrol
Old May 3, 2011 | 11:30 AM
pa4ul's Avatar
does ur miles till empty work on the dis?
Martinfitz09
Nov 3, 2013 03:13 AM
disguyb3fitt3d
May 11, 2008 01:13 AM
jal0003
Dec 6, 2007 04:06 PM
hofackerjk
May 23, 2007 10:59 AM
jose brito
Feb 20, 2005 12:31 AM
