Cooleant temp high light on
Hi,
After replacing timing belt, water pump and thermostat on my A4 V6 3.0L, the "coolant temperature too high light" is on. The coolant temperature gauge on the instrument panel is normal (at middle). It seems the coolant system is not circulating enough coolant through. The radiator is not very hot. Could that be a water pump or thermostat problem? How to check if the water pump is working correctly? Is there an easy way to check the thermostat without removing it from the car?
Thanks in advance.
Ben
Thanks in advance.
Ben
I followed the procedure in the Bentley manual. I opened the bleed holess on both radiator (on the metal pipe connected to the thermostat) heater hose, until coolant came out.
Do you know a way to check water pump is woking? I remember there was post describing how to do this a while back, but I can not find it now.
The upper hose (coolant going into radiator) is hot ( not as hot as engine block). The lower hose (out of radiator) is cold (or warm). Only the end of this hose close to the thermostat is hot. Could this be a thermostat problem? If the thermostat is stuck close, how could both sides of the valve are hot? Thanks.
Pbcrazy
Sep 7, 2012 04:25 PM
