Cracked Crankcase pipe assembly??
Old Feb 23, 2010 | 09:54 AM
PSULion21's Avatar
Default Cracked Crankcase pipe assembly??
So I'm at the stealership today getting my coilpack recall taken care of and they do their 28 point inspection. They tell me that I have a crankcase pipe assembly crack which needs to be replaced, as well as the valve cover gasket and cam adjuster gasket. I have a 2005 A4 B6. Is this typical? They want $1351 to do this. Is this reasonable? I assume this is something thats not a do it yourself type project. Any advice?
Old Feb 23, 2010 | 10:52 AM
shane.trammell's Avatar
There is a plastic pipe that goes into the three way breather that is known to break. its under the intake manifold closer to the back of the engine.
Old Mar 9, 2010 | 12:08 AM
NicholasPatula's Avatar
OMG $1300? Well to replace the breather pipe?? I replaced mine for free. Mine was cracked and all I had to do was take off the coolant reservoir, cut off that pain in the butt clamp off the tree way that was connected to the breather hose and pull out the ring for the bottom of the pipe. Very simple once you get that clamp off the 3 way hose.. wow..
Old Mar 9, 2010 | 02:07 PM
pa4ul's Avatar
yea that seems a bit wrong. ARe u leaking oil or anything. Has ur car had its tb changed and waterpump. If not i would say hold off on the gasket and wait till u have the change to change all at once.
Old Mar 14, 2010 | 09:24 PM
PSULion21's Avatar
Yea, I had a slow oil leak. I called a local Volkswagen dealer who quoted me under $700 so I had they take care of it. Now that its fixed, there's a huge performance increase! It's as if I was only getting maybe 80% acceleration prior to getting it fixed.
MyFreeAudi
May 9, 2015 05:25 PM
Exuberantt
Jan 6, 2014 09:26 AM
Subway
Oct 17, 2011 11:19 PM
jaimea6
Oct 22, 2009 05:03 PM
