Dipped headlight message -- is it the bulb?
Old Sep 6, 2012 | 12:09 PM
pa4ul's Avatar
nah man those torx screws are down there. And yea dont losen them all the way or they might fall further into the engine which is a pain! Ask me how i know! lol But yea losen those up and the whole light should slide right out. u might have to push a wire out of the way on the drivers side to see the screws but they will be there. dont take it to the dealer man let us know what help u need and well get u set straight.
Old Sep 6, 2012 | 12:23 PM
daxb's Avatar
The headlights (well the right one that still works) definitely self-adjusted this AM when I turned my car on in the garage with the lights off. Is there such a thing as auto dipped halogens or are all of them only HID?
Old Sep 6, 2012 | 04:08 PM
daxb's Avatar
I determined that my bulbs are definitely HID so ordered those same ones from Sonic sent priority mail. Now I just need to find a long enough torx wrench. The size is a 10, right? All I have are torx bits right now and they won't reach into the tight spaces on the inside of the car.
Old Sep 6, 2012 | 06:21 PM
pa4ul's Avatar
they should be the same size at the top. Just dont lose the bit or u will be screaming!
Old Sep 17, 2012 | 06:59 PM
daxb's Avatar
the bit fell out and rolled around the pan at the bottom but I got it back with a coathanger from the bottom of the car.
I changed the one bulb which took about 1.5 hours since those bottom screws required moving some other items around first but i finally replaced it. I understand it's best to replace both at the same time but the first took so long i'm waiting to replace the other. Thanks for your help!
Old Aug 11, 2013 | 05:02 PM
rshewmaker's Avatar
Default Dipped is now worse
I just want to clarify that a dipped headlight is not a bad bulb but something related to what's connected to it? My front right signal intermittently goes out and this
Both xenons work but no longer adjust on startup. So, what I want to know is this a ballast issue more than it is a bad bulb?
climber60614
Oct 2, 2013 11:42 AM
Jrmiller
Feb 25, 2013 03:03 PM
francoisboivin
B7 Models
Sep 24, 2011 10:44 AM
motleycl
Apr 8, 2009 08:50 PM
Snowwake8
Jun 10, 2008 01:43 PM
