drive shaft oil leak
Old Jan 22, 2010 | 11:28 PM
wonkaswilly's Avatar
Default drive shaft oil leak
Hi everyone, really need some help please. Saw a small puddle forming under the car a few days ago and went under for a closer look. Please see the photo. I did some searches, but I am quite honestly not sure what to query (I don't know what the specific area that I need help with is called). There seems to be some talk about center support bearings, but I don't think this is it (or is it). If any one has a DIY for this already, please point me in the right direction. I have a good amount of tools and am not afraid to dig in. The problem is that I cannot find a hanes or chilton for this model.
Is this doable on jack stands and are there any "while you're there" items I should be aware of.
Thank you for any help.
BTW, while I was searching for what this problem was, I saw an offer on blauparts.com at the bottom of the page that they will rebuild certain model driveshafts for free. No affiliation, just passing on what I saw.
http://www.blauparts.com/audi/audi_d...pair_kit.shtml
Chris
2002 Audi A4 B6 Quattro 3.0 automatic, 75K miles
Old Jan 23, 2010 | 10:06 AM
Dan1969's Avatar
seems like your output shaft out of the transmission. Is it right in the front by where the cats are?
Old Jan 23, 2010 | 11:29 AM
Hi Dan, it is connected to front part of the car. Not being familiar with this car (let alone a quattro), I assume it is the transmission. The other audi forum that I posted this question on said that it is probably the oil seal on the center diff. This is the link to a DIY that they gave me: http://www.audizine.com/forum/showth...nsmission+Seal
I just need to find a downloadable repair manual that is less than $100 so I can get the torque specs and the obvious items that may have been left out of the DIY. Can't afford to mess this up-its my DD.
Old Jan 23, 2010 | 11:52 AM
Dan1969's Avatar
That DIY here not working, but the link they gave you on AZ is fine. Just follow the instructions and is really not that difficult, I believe you are going to have to drain your transmission fluid and refill it.
Old Jan 23, 2010 | 10:06 PM
shane.trammell's Avatar
umm it takes a special tool to refill this trans, cant even check the level without getting the car to a specific temperature. i work on my car too, but i wont touch the trans. the only thing the dealer gets to work on.
Old Jan 24, 2010 | 01:16 AM
Dan1969's Avatar
is just an hand pump for oil.
Old Jan 24, 2010 | 06:24 PM
Audi Tek's Avatar
Tech Certified
its called a front prop shaft seal....
you have to lower the exhaust...
you'll need a Torq T45, a 8mm, a 6mm allen sockets
some sort of hand pump for fluid.
Seal installer.
its not an easy job laying on your back in a driveway.
Old Jan 24, 2010 | 09:45 PM
thank you for the replies. I've read in a couple places that this is also called a transmission output seal. Trying to source locally-no hope yet. Will call Audi dealership monday when they open. Anyone have the audi part number and/or OEM #.
Thank you
Old Jan 24, 2010 | 09:47 PM
forgot to ask a very important question-is this safe to drive? I assume that as long as it is not pouring out, the seal is still keeping most of the fluid in the tranny.
Old Jan 25, 2010 | 09:09 AM
Dan1969's Avatar
it should be ok as long as there's fluid.
sillyd_71
Mar 12, 2015 11:57 AM
Ryan420
Mar 11, 2013 11:06 PM
kbevere
Oct 14, 2010 09:36 AM
davisbr9
Feb 10, 2010 01:00 PM
graham80
Dec 13, 2005 10:14 PM
