dv problem
Old Mar 24, 2012 | 11:56 AM
luis_16_r's Avatar
Default dv problem
Everytime I connect the vacuum line on the dv I get no boost at all ,once I disconnect the vacuum line from it I drive it for a little bit and it starts boosting all the time . Any1 have an idea what's goin on , I need help I'm very frustrated
Old Mar 24, 2012 | 12:02 PM
Dozanti's Avatar
It's probably sticking open, and is bad. See if you can source a cheap used one to see if it fixes the problem. There's a way to test it I believe by disconnecting it and pressing it open, it should stay open? Someone will chime in about how to test it
Old Mar 25, 2012 | 09:49 AM
tofast2belast's Avatar
it opens because of vacuum, when you close the throttle, there is a vacuum in the intake manifold.
what you need is a vacuum pump. remove diverter valve and attach vacuum pump to valve and it should open, if you relieve the vacuum it should close. if it doesnt, you can remove the top and try regreasing the diaphragm... dont drive with out it connected, you will do damage to the turbo and possibly throttle body over time.
Old Mar 25, 2012 | 12:11 PM
luis_16_r's Avatar
Ok thanks , the valve was recently replaced like 3 months ago . When I took it out I pressed it in n it wasn't staying it closed right away . But wen I put the vacuum pump to it , it does stay open .
Old Mar 25, 2012 | 12:14 PM
luis_16_r's Avatar
Is there any possibility that I broke it by cleaning it with gum cutter lik a month ago
Old Mar 25, 2012 | 12:28 PM
luis_16_r's Avatar
Or could the valve be plugged in backwards ?
Old Mar 26, 2012 | 07:28 AM
heres a makeshift diagram lol.
but no that wont make it stick open.unless your boosting it might push the valve up if it was installed backwards... take it out and clean it..
Audi area: Audi A4 B5 DIY: Install/Cleaning of Aftermarket Diverter Valve
Old Mar 27, 2012 | 09:28 AM
luis_16_r's Avatar
I finally found the problem , one of the hoses from the n75 to the turbo had a hole in them , I wasn't able to c it becuase it was very dirty . Thanks for all the help , really appreciate it
Old Mar 27, 2012 | 01:10 PM
Dozanti's Avatar
Glad you figured it out, now if someone has similar symptoms we have an idea where to immediately look.
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
