Electrical Problems
Old Mar 23, 2009 | 06:58 PM
Jimbezy's Avatar
Unhappy Electrical Problems
My 05' A4 Ultrasport is getting long in the tooth with 97K miles and little problems keep popping up, but I digress.
For some odd reason the Dimming mirror and compass no longer work, like its not getting power and my trunk popper also does not work and I have to use the key fob to get it to pop open. I've checked all the fuses and all were good except the rear cig lighter which I replaced.
So, what could the problem be and how dio I fix it? Im tired of being blinded when I drive at night, which I do a lot, and where is the other fuse panel? Even on the regular one it says there are more fuses at the "e-box", who knows where that is though! (I've already checked the ecu area)
Thanks in advance for your help
Old Mar 24, 2009 | 08:23 PM
auditech79's Avatar
There is a little electrical connector that goes to the mirror behind the plastic trim piece. Try popping that part off and see if the connector is still on there. If it is i would invest in a vag com www.ross-tech.com which is a lap top scan tool software which will allow you to diagnose just about everything on an audi. You just have to buy the cable.
Mercy404
May 2, 2015 09:22 PM
kraiv
Jun 28, 2008 03:48 PM
02A418T
May 1, 2007 10:57 PM
baba
Mar 12, 2007 03:02 PM
AndyMelvin
Dec 8, 2005 02:35 PM
