Electrical problems???? No turn signals or high beams
Old Jun 26, 2013 | 09:01 PM
  #21
alvy's Avatar
Also...
Has no fog lights..only one headlight works...no high beam function...no sunroof control...
also Vagcom cannot communicate with controllers for central convenience,central electrical and Aux Heat COntrol locks when scanning
Old Jun 27, 2013 | 02:08 PM
  #22
pa4ul's Avatar
sounds like your electronic control module got shorted out somehow. You can find one on ebay for under 200 dollars and if u know someone with vagcom u can recode it to your car. U can actually access the module underneath the kick panel of the steering wheel. Pull off that panel and get on the floor and look up. U will see this module. http://www.ebay.com/itm/02-05-AUDI-A4-A4Q-S4-ONBOARD-POWER-SUPPLY-CONTROL-MODULE-COMPUTER-8E0907279F-/261226302723?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAudi%7CYear%3A2003&hash=item3cd24d0d03&vxp=mtrU can actually open it up and see if there is any signs of the board getting fried. that would be my best guess besides the actual control module for the car. Which is a bit more pricey.
Old Jun 27, 2013 | 04:36 PM
  #23
alvy's Avatar
I will give it a look and post back results. Thanks!
Old Jun 28, 2013 | 05:41 PM
  #24
02A4kid's Avatar
hey guys, i wouldnt say the EXACT same thing is happening with my car but there is a blinker issue that has gotten worse. basically when i turn left and put the left blinker on it works 100% of the time, but when i put my right blinker on it works about 25% of the time and the other 75% of the time it will blink left a few times before switching to the side that SHOULD be blinking. sometimes itll blink twice on the left then go back to right or other times it will just continuously blink left with the stalk in the right turn position. it is highly annoying and it makes me look like im lost/drunk/stupid and its really getting to me. anyone ever have this issue or know what to look for?? thanks!
Old Jul 1, 2013 | 01:39 PM
  #25
pa4ul's Avatar
Hey i would think it might be your turn signal stalk going out. IVe actually read a couple of people having same symptons and they either dust out the inside of the stalk or completly replace it. MIght check into that.
Old Jul 14, 2013 | 03:12 AM
  #26
dukefan's Avatar
alvy,
Fog lights are out on my car too.
I've been reviewing some wiring diagrams and it appears that the lack of fog lights could be an indicator that the load reduction relay is not energized. I plan to check this relay next week.
Further, it appears that the relay gets energized by "grounding" through the steering column module (not sure about this...would appreciate comments from any audi tech).
Thanks.
Old Jul 16, 2013 | 05:13 PM
  #27
pa4ul's Avatar
have u scanned the car for codes. Or even scan the central convience module with vagcom. . .
Old Nov 16, 2013 | 05:02 PM
  #28
alvy's Avatar
UPDATE!:
Broke down and took it to a local euro garage. Was told my onboard power module is suspected. I just replaced it myself (bought the wrong one for garage ) but still the same issue..I'm taking this has to be recoded? I have Vagcom but without old one working or able to communicate with how can I reprogram this? Or should I just take it to the stealership? Thanks guys...I know im a newb ;(
Old Nov 19, 2013 | 04:41 PM
  #29
pa4ul's Avatar
hmm u might search google. I know that there is a diy from rosstech on how to recode that power module. IT has to do with inputting values for how the lights work and all that fun stuff! Good luck.
Old Dec 28, 2013 | 01:41 PM
  #30
christophergreen123's Avatar
hi, having problems with my a4 b6 2002 turn signals, wipers and horn not working, also when parked up for the night something draining the battery. I also have no power windows.. changed my steering control module today with no joy.. still have same problem???
