Engine Shudder after APR stage 1
Old Apr 9, 2009 | 07:56 AM
ezrider1978's Avatar
Default Engine Shudder after APR stage 1
Got the car chipped couple of weeks ago, its been running great. But this morning, driving in to work, I was parked at a stoplight and suddenly the engine shuddered-the rpm dipped to around 300 and immediately bounced back to 800. After that-nothing- everything is running fine. Has this happened to anyone before?
I am worried that this is a bad sign- that something is going to fail soon.
Plus, my car is under warranty but they won't fix anything if they think it was caused by the chipping.
Old Apr 9, 2009 | 10:04 AM
xSilent13x's Avatar
It might be a Coil Pack on the brink of death. They usually go after a chip is put in. Common problem not too expensive either prolly $40+
Old Apr 10, 2009 | 08:32 AM
the garage where I got the car chipped was very helpful- they said it was nothing to worry about- this is what he said:
" If the car wasn’t up to temperature completely it could have been the oxygen sensor coming on line. Or the secondary air injection system turning on and/or off will also raise and lower the idle"
One thing about the coils- how does a coil just "go"? I mean, does it get worse over time? It doesn't make sense-I mean, putting a new coil in doesn't get rid of the underlying cause that made the coil go, right?
Old Apr 10, 2009 | 10:16 AM
xSilent13x's Avatar
No...but they are known to go bad after they are put under strain like a chip. It doesn't mean you're hurting the coil packs its just that they are being worked 100%. I keep an extra set in my trunk just in case because 2 popped on me already so I switched to the 'E' model packs and I haven't had a problem since.
Old Apr 10, 2009 | 11:16 AM
pa4ul's Avatar
ecs tunning
yellow_submarine
Nov 25, 2014 09:51 AM
hotttsauce84
Sep 2, 2014 02:25 PM
Joellarogers
Aug 21, 2013 12:40 AM
spacemonkeys9999
Dec 25, 2011 09:11 PM
Constantine
Jan 13, 2010 09:58 PM
