Engine vibration even when idling
Old Mar 25, 2008 | 02:50 PM
auditurbo381's Avatar
Default RE: Engine vibration even when idling
loss of power may occurr. however i didnt expreince any. let us know what you find.
the car only was rough at idle in my case, and any throttle applied it smoothed out
Old Mar 25, 2008 | 03:10 PM
Audinick81's Avatar
Correct me if I'm wrong, but the inline check valve is only found in turbocharged engines, right? I have 3.0 V6.
Thanks!
Old Mar 26, 2008 | 12:15 AM
SouthernAudi's Avatar
You're right ... only for turbocharged motors ... that"s mybad, I forgot you had the 3.0
Old Mar 29, 2008 | 08:08 PM
Audinick81's Avatar
I believe I might have found out the source of my A4 3.0 vibration problem.
I found a little hose connected to a small plastic resonator ( 06c 133 911 b) leaking air.
This hose is connected to the air duct between the MAF and the engine causing the car to run lean on gas. The rubber hose apparently is not sold separatly so I have to get the whole hose/plastic resonator which only Audi sells for @ 90 us dollars.
I'm getting the part hopefully next week and I'm going to install it myself, and hopefully the car will run good after that
Old Mar 29, 2008 | 10:32 PM
My replacement of the inline check valve didn't fix the vibration ... still searching for the problem.
Old Apr 17, 2015 | 10:54 PM
painterboy2000's Avatar
Default audi 2003 a4 1.8t
How many vacuum lines does this car have. Car has vibration when idling
adrian825
Jan 18, 2014 01:28 AM
Ebbs22
Feb 10, 2012 04:47 PM
divil
Jan 26, 2011 10:18 AM
peter121
Sep 13, 2008 08:57 PM
acollicott
Jan 9, 2008 11:49 PM
