few questions regarding transmission fluid change, pls help!!
Old Jul 15, 2009 | 01:36 AM
kchao2000's Avatar
Default few questions regarding transmission fluid change, pls help!!
I am thinking to change transmission fluid. The car is 2004 A4 3.0q running at 71000 miles now. Here are my questions:
1. ECS Tuning sells transmission fluid complete kit, is it good?
2. Do I need triple square (12 points) to remove drain plug? I heard 3.0 engine only need 17mm allen?
3. How many liter of ATF do I need?
4. Any special steps I need to pay attention?
Thanks for your help.
Old Dec 15, 2012 | 10:44 PM
2003audiA4avant's Avatar
BUMP!!!!
I need to do a change as well. any ideas?
Old Dec 16, 2012 | 01:58 PM
tofast2belast's Avatar
look under your trans pan and see what socket it will take... mine was an allen key. but if its the 12 point, pepboys sells a set for $10 or so
Old Dec 17, 2012 | 10:50 AM
I bought a kit from blauparts.com and Im going to try. I do not haw a bg com to meaure tranny temp so that's what I'm worried about. I know the procedure to fill but how long does it usually take from a cold engine/tranny to reach 40 degrees Celsius? I'm goin to fill it up as much as I can before starting, then start it and pump ATF consistently while someone goes through the gears twice. I'm just not sure when to stop ( tyranny fluid reaches 40 degrees) any ideas? Thanks
Old Dec 18, 2012 | 04:25 PM
That's just over 100*F... Just warm engine to operating temp by driving around a little. This will warm the fluid up. Granted the trans will warm faster than the engine will if your driving it around
Old Dec 19, 2012 | 12:07 PM
NoAudiGuy's Avatar
You can get a cheap digi thermometer from harbor freight and use it to monitor temps. I've seen posts claiming that this worked just fine.
You can always pickup a $25 knockoff Vag.com off the net (search VCDS or 11.11.10 or 11.11.11 or Hex Can) that will read those banks/info.
Old Jan 16, 2013 | 04:43 PM
Noaudiguy. Your smart. I bought a 15$ cable, downloaded te free software and everything worked amazing. No more kicking drives smooth.
Old Jan 16, 2013 | 04:57 PM
01 Avant's Avatar
what cable did you buy and where did you find the software?
wdills
May 21, 2015 03:43 AM
pointman0853
B7 Models
Nov 26, 2009 07:29 PM
davidp423
Oct 6, 2008 05:32 PM
moeron7
Sep 24, 2007 05:25 PM
jason23silver1
Sep 12, 2007 05:04 PM
