Flashing LED Numbers Indication?
Old Feb 17, 2012 | 04:23 PM
Codyk1992's Avatar
Default Flashing LED Numbers Indication?
http://tinypic.com/r/2lctw0k/5
If anyone knows what those numbers indicate when they are flashing,
please help it normal happens after a good 4 hours of driving my car. Sometimes it will happen after a hour or so, but mostly after a long drive on the way back is when it will pop up and continuous flash till I shut off the car and start it back up or just press the button.
I can change it back to gas-mpg etc... and the LED where that "N" is will light up so I'm pretty sure the LEDs there are not bad.
2:00 And what looks to be a "N" <--- not sure though
Old Feb 17, 2012 | 04:40 PM
Dozanti's Avatar
Your LCD screen is starting to go bad.
Old Feb 17, 2012 | 04:41 PM
Dozanti's Avatar
They are damaged by heat/old age/vibration. That would make sense since it happens after being used/on for a long drive
Old Feb 17, 2012 | 04:57 PM
Codyk1992's Avatar
Well I can understand that When it is hot out the top part always goes dim but comes back full strength later on.
But this still doesn't tell me what that flashing sequence of numbers with some characters on the end means, unless you are saying that the instrument cluster is going bad and that is what it is indicating, but I don't think that's what your saying.
What I am trying to find out is what the 2:00 flashing every 2 seconds means. Im sure it is something someone on this forum knows for sure.
Old Feb 17, 2012 | 05:04 PM
Dozanti's Avatar
Ahhh I didnt see your last sentence. Sorry about that
Old Feb 17, 2012 | 05:08 PM
Codyk1992's Avatar
Its all good, I figured it out from another Audi Forum supposedly It is a indication that you have drove for 2 hours and you need to stop and take a 10-15 minute break, so Its no biggie.
Old Feb 17, 2012 | 06:31 PM
pa4ul's Avatar
its your car telling u to rest. U can clear it on the stalk on the steering column.
AllRoad Ken
Feb 15, 2015 08:41 AM
Enonymous
Mar 19, 2012 02:33 PM
BenjaminH
Feb 13, 2011 11:34 AM
xewax
Aug 19, 2009 11:08 AM
smoovmusicdj
Mar 17, 2008 04:33 PM
