flickering fog lights
Old Jan 3, 2010 | 12:31 AM
timmay074's Avatar
Default flickering fog lights
so when im driving at night time with my fogs on, i would say 1 out of 5 times i drive with them ON they start flickering. once they start flickering nothing will stop them flickering, even switching the fogs off. New thing i tried is pulling over and turning the car off then back on, then i keep the fogs off then it is fine...usually
any insight to this would be great
Old Jan 3, 2010 | 10:38 AM
Dan1969's Avatar
hmm, do you have the independent foglights? Have you checked for anything obvious like loose wires/cables? Just asking, haven't heard of this before.
Old Jan 3, 2010 | 03:39 PM
timmay074's Avatar
they are the stock fog lights that came with the car and idk if it could be a wire or calbe, they both do it at the exact same time
i can take apart the foglight apart to check, but im not to sure if it could be a loose connection
Old Jan 4, 2010 | 12:16 PM
pa4ul's Avatar
Odds are either ur bulb in not sitting in the housing correctly or u have wires exposed. . Check up on it.
Old Jan 4, 2010 | 04:47 PM
timmay074's Avatar
i wont be able to get to it any time soon, im back at school now and no access to a quality car wash (dont want to take apart the fogs if salt and all snow crap is gunna get in them) or access to my tools ill check that as soon as i make my way home again. ill update.
Old Jan 4, 2010 | 05:01 PM
Gordon Freeman Jr's Avatar
Why are you driving with your fog lights on all the time?
Old Jan 4, 2010 | 05:15 PM
Midniteoyl's Avatar
Because he want too.. Maybe he likes the increased brightness the fogs give while on back roads..?
I'm wondering why you ask? Is this something that is destroying the US too? maybe your worried the Light Elves are not getting paid?
Old Jan 4, 2010 | 06:33 PM
pa4ul's Avatar
aint no shame in getting a little extra light output. I have my fogs aimed just high enough where u can see them over the hood. Helps tons on back roads.
Old Jan 5, 2010 | 11:39 PM
scskim's Avatar
sounds like a grounding problem?
Old Jan 6, 2010 | 11:20 PM
CMoriart's Avatar
I had the same problem... except it was the headlamps as well. At first I thought it was from the location of the GPS sensor/tracker. They installed it on a mag pad, right by my headlamp switch, but closer to the windshield. To get my lights off, I would have to put the headlamp switch in the off position and push the headlamp switch in. Apparently, this is how you take the switch out
I ended up replacing the headlamp switch and fixed both of my problems. 181.00 from the stealership.
hoovdiddy
Jul 5, 2017 10:19 AM
ryan_2012
Sep 9, 2011 04:59 AM
dunanga
Jan 25, 2009 04:15 AM
RyanSweeney
Dec 24, 2008 12:50 AM
OOOOA4
Jan 19, 2008 07:48 PM
