Gremlins, Gremlins making dash christmas tree
Old Mar 11, 2016 | 09:40 PM
synesthesia's Avatar
Default Gremlins, Gremlins making dash christmas tree
Ok, hoping someone may have a more clear answer.
05 B6 Ultrasport 3.0- 6spd manual, 87k
First off, this is not a daily driver, infact before this week the last time it was driven was october - stored inside over winter.
Issue 1 - Battery light comes on from time to time, always hooked up to trickle charger if parked more then a week. No starting issues, battery 3-4 years old, alternator only 2 years old. Had it tested and both passed but alternator was only charging at 13.3 volts... Belt is also only 2 years old, Several ECS lightweight pulleys, new tensioner so no slipping, cables tight.
Issue 2 - serious misfires at random. Had only happened 3 times, each time if I turn off engine and restart it seems to be fine. Generates flashing CEL, multiple misfires on different cylinders each time, car basically undrivable. Turn it off, then back on and been fine.....
Issue 3 - ?????? When battery light was on I did a decent take off and mid 2nd gear red brake light flashed and made beeping noise, traction control light on and abs light on. Stopped, turned car off and they went away. Happened again down the road, stopped car, turned off and went away.
No codes that I can pull with VCDS lite
Drove 60 miles, no other lights, cleared misfire codes and disconnected battery for 10 mins. On reconnect the traction control light is on, nothing else.
So...I know it's an Audi and all, but has anyone seen this before? Haven't done anything to car besides oil change and wheels in past year.
Thanks
Audiz123
Apr 20, 2014 08:42 AM
claytonp
Mar 15, 2013 07:25 AM
linkstabile
Feb 18, 2013 07:57 AM
twoeightquattro
Oct 17, 2010 10:21 AM
