HELP!!!!!!!!!!!!!!
Old Jun 26, 2008 | 12:10 PM
silveraudib6's Avatar
Default HELP!!!!!!!!!!!!!!
coolant flush leaking...... that is what the machanic said what is wrong with my car does anyone know what this means and how much it will be to get fixed he told me around $282
Old Jun 26, 2008 | 12:18 PM
swrt83's Avatar
Default RE: HELP!!!!!!!!!!!!!!
ORIGINAL: silveraudib6
This isn't a horrible problem to have, unless you can't bare to live without the A/C! lol. With that said, the coolant is just the fluid your AC uses. 282 doesn't sound too bad to be honest. my dealer quoted me above 300 i believe for a coolant flush (which i read in a forum after i got home that the coolant should last a lifetime so long as its the original fluid from audi) i would imagine the 282 is for a repair and to top off..
Old Jun 26, 2008 | 12:22 PM
well how much repair is there to be done they make it seem like all u need to do is tape up the crack where its leaking from and call it a day
Old Jun 26, 2008 | 12:35 PM
swrt83's Avatar
Depends, its usually a case by case basis. Maybe a hose ripped in which case they just replace it. If it involves a connection then it gets a little more technical. Its hard to say without a picture showing the problem.. unless someone else can chime in that has had actual experience fixing a coolant leak or knows if its a common problem..
Old Jun 26, 2008 | 12:57 PM
audiprotein's Avatar
Coolant is the antifreeze. It helps to cool down the engine. It might cause the a lot of problems and to overheat the engine... Pay attention to your gauges, dont let it overheat. Id fix that asap.
Find out where its leaking.
Old Jun 26, 2008 | 12:58 PM
ORIGINAL: swrt83
I think u meant to FLush the coolant.
Old Jun 26, 2008 | 12:59 PM
ORIGINAL: audiprotein
ORIGINAL: swrt83
It might cause your engine to overheat
Old Jun 26, 2008 | 01:00 PM
ok well i was told that my transmission gasket is leaking i have oil leaking from some kind of cam seal and the coolant flush is leaking i know that i have to get all this fixed but what is the most importand one to get fixed first and i have been lookign at my gadges the temp stays in the middle....is that normal
BTW, that thing that your A/C uses caleld FREON
Old Jun 26, 2008 | 01:01 PM
swrt83's Avatar
ORIGINAL: swrt83
Correct. Did I not make that clear enough? I guess not, sorry.. haha.
I did read this shouldn't be necessary with any Audi's (manufacturer's lasts a lifetime): can you confirm?
