HELP!!!!!!!!!!!!!!
Old Jun 26, 2008 | 01:07 PM
audiprotein's Avatar
Default RE: HELP!!!!!!!!!!!!!!
Coolant has nothing to do with A/C. Freon is that "liquid" for the ac. Coolant is the liquid to cool down the engine. Which one are u asking about? ))
Old Jun 26, 2008 | 01:10 PM
euro_2nr's Avatar
WRONG. The manuf. manual also says oil changes should be done every 15,000 miles. That's the max amount of raping your engine can take. Its a good idea to do it every 60-70k miles. If you pay attention to your reservoir its probly really low. Every car leaks a little or some inevitably evaporates. You can add coolant (G12 only<pink sh*t&gt or get the hole thing flushed.
Old Jun 26, 2008 | 01:12 PM
silveraudib6's Avatar
lol ok guys what should i do?
Old Jun 26, 2008 | 01:19 PM
euro_2nr's Avatar
If you have actually found a fluid leak then I advise you to fix the leak (probly just a lose clamp or kinked hose) and do a coolant flush if it has never been done. If its been recently flushed then just add 1/2 water and 1/2 G12
Old Jun 26, 2008 | 01:20 PM
No no... we are taking different things. One guy talks about freon and AC the OP asked about coolant leak.
Old Jun 26, 2008 | 01:21 PM
swrt83's Avatar
ORIGINAL: audiprotein
haha, this is very true. i'm mixing up my fluids, how elementary of me! in any event, i was asking if you could confirm about the freon flush being not applicable. i guess a coolant flush would be required.
silveraudi - sorry for screwing with your head. sincerest apologies!!
Old Jun 26, 2008 | 01:25 PM
euro_2nr's Avatar
EDIT: DISTILLED WATER.
Don't go putting Aquafina in your coolant
Old Jun 26, 2008 | 01:38 PM
  #18
euro_2nr's Avatar
Freon can go out at any time. And it doesn't get flushed it just gets recharged.
Old Jun 26, 2008 | 01:40 PM
  #19
Papachristou's Avatar
audi g12 is supposedly lifetime but gets a pretty good flush when you do the timing belt or rear coolant flange... no need to actually "flush" it
Old Jun 26, 2008 | 01:45 PM
  #20
swrt83
Iguess it depends on how often u use your AC.I think mine is on its way out. And i've never heard there is a lifetime warranty ona freon. its like your brake pads, you gotta change them when they are on the way out.
And OP i would just do the full coolant fluch with a new coolant instead of adding the water, make sure it is G12.
