helpp!!has anyone done timing belt,waterpump,thermostat??
Old May 20, 2008 | 10:21 PM
aznmpr's Avatar
Default helpp!!has anyone done timing belt,waterpump,thermostat??
Can someone help me with this one... i have a 2004 1.8t 6speed my car started overheating... with 56k on it.
so i decided to order the ultimate timing beltkit and thermostat from ecstuning.com. but i cant seem to find any DIY for b6..
want to know if anyone hastaken pic or have performed this on their own...ifyes please let me know my part should be coming in this thursday. Also let me know ifandy's originalTiming belt DIYwould be the same for b6..
THANKSSS
Old May 21, 2008 | 12:37 PM
Papachristou's Avatar
Default RE: helpp!!has anyone done timing belt,waterpump,thermostat??
there are several DIY guides on www.audizine.com and www.audiworld.com i used those to do mine, easy DIY. just be sure to mark both your crank and cam sprockets on the teeth and block with whiteout and make sure they are both at the same spot when u are done. i marked across the belt too and just matched it back up
Old May 21, 2008 | 07:20 PM
aznmpr's Avatar
thanks... lucky i have those printed out. Did you torque the bolts by the specs? if so.. can you please let me know the info on how much torque should be on each bolt?
Old May 22, 2008 | 10:33 AM
which bolts? i just snugged them all in, i used locktite on all the water pump and belt tensioner bolts, dont over torque them.
iheartmyS4
Mar 9, 2009 11:03 PM
Boober
Aug 4, 2006 08:29 PM
auttiquattro
Jul 19, 2006 07:57 AM
CaliA4
Apr 17, 2006 12:35 PM
