How do you remove the light switch?
Old Dec 14, 2011 | 11:13 AM
d21burggraf's Avatar
Default How do you remove the light switch?
I am going to be installing my ECS Boost gauge tonight and need to remove the headlight switch so that I can tap into the wires. Can someone tell me how to remove and pull out the switch so I can get to the wiring?
Thanks!!
Old Dec 14, 2011 | 11:25 AM
etzbseder's Avatar
You're supposedly able to just yank on it. I didn't want to do it, because I thought I was going to break it, so I actually removed the bolts holding the knee plate on and just removed it from the other side.
Old Dec 14, 2011 | 08:17 PM
jdahlen24's Avatar
Read this.
Old Dec 15, 2011 | 10:07 AM
olstyn's Avatar
jdahlen24's link has it, but if that's too much reading for you to find the one piece of info, here's what you need:
"Yank" isn't quite the right word. What you do is push in on it (about 1/2 inch in), then turn it clockwise slightly (same as you would to turn on the lights, but it'll only turn about halfway to the first setting), then pull out. It should come out quite easily.
kduznetsov
Apr 10, 2011 10:47 PM
jackson101
Sep 23, 2010 09:24 PM
porschefan
Aug 2, 2009 12:57 PM
ima_slap_joO
May 31, 2008 09:55 PM
a6avant
Jan 1, 2006 10:25 PM
