How To Run with Fogs Only
Old Feb 14, 2008 | 08:40 PM
04a4's Avatar
Default How To Run with Fogs Only
Ok,... I know this has been posted over and over... I Vag-com 'd my car and changed the settings to all the possible country codes. It was already set to the all other countries code... when i changed it to USA, Canada, or the other countries it made my headlights stay on w/out the **** being turned... ??? any ideas???
thanks
Old Feb 14, 2008 | 08:45 PM
dan's Avatar
dan
Default RE: How To Run with Fogs Only
thats exactly what the Canadian country code does. Unless you have an 02 A4 you need to rewire your headlight switch for independent fogs. Otherwise you have to settle for sidemarkers and fogs all the time.
Old Feb 14, 2008 | 09:08 PM
M¥§T's Avatar
Is it possible to run with only fog lights on an '02, because it appears that the switch won't come out to the fog lights on position unless at least the parking lamps are on.
Old Feb 14, 2008 | 09:11 PM
dan's Avatar
dan
your side markers will always be on when the fogs are on. Even on mine the side markers are on. Luckily though, the ecodes re-route the side markers to the city bulbs so it looks good instead of having the orange lights.
Old Feb 15, 2008 | 10:46 AM
Papachristou's Avatar
have a 02 model and do the vag com mod
since yours is an 04 either give it up or rewire your headlight switch
Old Feb 15, 2008 | 08:20 PM
AudiOso's Avatar
Can you just get the 02' headlamp switch and then VAG it to set it for Canadian country code?
Old Feb 15, 2008 | 08:36 PM
dan's Avatar
dan
it's not the switch that controls it. It's the headlight computer module. either way your going to have the side markers on as well.
Old Feb 15, 2008 | 08:45 PM
bustanut's Avatar
^^^ What he said. And, the >'03 wire splice is a simple 5 minute operation that is easily reversable. There is a how-to on either AZ or AW.
But also as mentioned, you've got side markers no matter what unless you completely re-wire the things. But fogs without headlights works well, especially with clear corners or ecodes with city lights.
Old Feb 16, 2008 | 12:11 PM
PandaXpress's Avatar
i have an 02 and i have that mod, its alrite nothin special
but ya so far only the 02s can be vaged to do it
A4 2000
Jan 30, 2012 09:08 PM
Gigantor
Apr 6, 2009 09:17 PM
jaw knee
Mar 27, 2009 12:13 PM
cburn25
Feb 22, 2009 07:39 PM
PCBOI808@HOTMAIL.COM
Jun 30, 2008 05:07 PM
