How to undo connectors behind ecu on 2003 a4
Old May 12, 2012 | 03:14 PM
tpaudi's Avatar
Default How to undo connectors behind ecu on 2003 a4
Hi:
I am pulling the engine and need to undo the connectors behind the ecu that go to the engine harness. These are not the standard audi connectors but something that look like they have clips on two sides of the connectors. I assume that there is a trick to unclip the connector and then slip them apart. If someone out there could tell me the trick, that would be great.
Thanks in advance.............
Old May 13, 2012 | 07:43 PM
tpaudi's Avatar
Default how to........
Figured it out for those that care. I used a long shaft, thin blade screwdriver and gently lifted the plastic tang on each side while pulling the connector upward. It helped to hve the hood off to do this.
Old Jan 24, 2013 | 06:03 PM
haygood's Avatar
Thanks. That is exactly what I was searching the net to find. If anyone has a picture of the disconnected connector, that would be very helpful.
This looks like it might be the same connector:
http://www.efiexpress.com/catalog/im...connectors.jpg
kiwi60
Jul 25, 2012 10:42 PM
207
Feb 13, 2011 12:19 PM
vtraudt
Nov 22, 2010 02:23 PM
tjb1703
Aug 6, 2010 01:54 PM
mnsirx
Aug 16, 2007 10:51 PM
