Idle Problem??
Old Dec 1, 2008 | 04:04 AM
2003 audi a4's Avatar
Member
Unhappy Idle Problem??
When i am at a stop sign or red light the idle seems to randomly studier and it will do this almost every time i am at a stop its been doing it since i bought it about 3 months ago but it didn't bug me but now it is.....if anyone has any info about what you might know whats going on it will be a big help, Thanks
Old Dec 1, 2008 | 08:17 AM
Myst420's Avatar
First off, can we get a few details about the car. Second, have you checked the simple stuff, spark plugs, fuel filter, air filter, etc?
If it's a 1.8t, that could be signs of a coilpack going.
Old Dec 1, 2008 | 04:46 PM
Member
the car has 69,000 miles i havent checked the spark plugs etc not sure on the maintance ill look and see if it has it the manual
Old Dec 1, 2008 | 05:04 PM
Member
and also no engine mods done
Old Dec 1, 2008 | 08:19 PM
Myst420's Avatar
Well, spark plugs would be the first place I would check. That's a cheap and easy fix. Then check out the coilpacks. Also, make sure you are running a high octane gas; I know my car seems to run a little off if I ever run regular gas.
Old Dec 1, 2008 | 08:28 PM
Member
yeah i run 91 all the time but ill check the spark plugs then the coil packs
Old Dec 2, 2008 | 01:12 AM
krystallbluea4's Avatar
He said it only happens at idle. Coilpack is all the time. Clean your maf and replace your plugs to start...before you spend more time diagnosing. Maf cleaner and copper plugs total cost $20.00 and its a good maintenance habit anyhow. Get copper core plugs, change them everyother oil change and clean your maf every time you change your airfilter. Maintenance is key and lack of it is usually the cause of most problems.
Old Dec 5, 2008 | 05:14 PM
OC1.8T's Avatar
I also have an 03 b6 1.8t with 72000 miles and 2 weeks mine was doing the same thing i toke it in and at first my machanic said with the b6 models ther was a ecu glitch with cold temp starting witch makes the cyilinders to miss fire which causes the studering it could be that. Or you my have a broken vacum hose which ended up being the problem.
Old Dec 9, 2008 | 07:17 PM
mrturbo's Avatar
I had pretty much the exact same problem at the same mileage recently. Eventually the check engine light came on, turned out to be several intake/vacuum leaks. The one large hose that goes across the turbo had a huge hole burned through it. After replacing 4 hoses the leak was fixed and the car idles fine now, and the performance increase was massive!
juha01
Apr 3, 2014 01:56 PM
justinclarke
Nov 25, 2010 04:03 PM
audiltr
Apr 24, 2008 08:41 PM
cbailey_369
Nov 19, 2007 04:00 PM
