Just got boost gauge...boost/vaccum leak??
Old Jun 4, 2012 | 08:16 PM
to4xxx's Avatar
Default Just got boost gauge...boost/vaccum leak??
Hi guys,
After having flashed the APR stage 1+ and injectors, i didnt really see much performance increase from stage 1.
So i installed a boost gauge today. got a sunpro at autozone for $30.
Now heres the problem, whenever i floor it, accelerate hard, the boost gauge maxes out to 20 psi(not sure if psi, but they label it "press"). There is no way in hell my ko3 is pushing 20 psi, right??
If i accelerate a little bit, saying 0-20 in first gear, the gauge reads 10-15 psi. Still i think thats a little high.
Can someone please help me solve this problem?? I feel like my stage1+ is slow for 235hp
Edit: It is an 2002 A4 1.8T Fwd CVT
Old Jun 5, 2012 | 01:27 PM
pa4ul's Avatar
that sounds about right. I think stock the psi is somewhere around 10 to 12. . . Stage 1+ should peak at around 18 to 22 psi depending on location and weather. . And hold 12psi until redline.
Old Jun 6, 2012 | 01:23 PM
to4xxx's Avatar
Does stage1+ improve top speed performance or acceleration?
Old Jun 6, 2012 | 01:49 PM
BesI's Avatar
whats your millage on your cvt? just curios since everybody has problems with cvts?
Old Jun 6, 2012 | 06:20 PM
pa4ul's Avatar
hmm how fast u looking to go. i know our governor clocks out somewhere near 135 or so. it well help all around but mostly acceleration is where u tend to feel it.
Besi start a thread with cvt mileage just so we can keep tabs on when they got out
oo i have 147,000 on my cvt.
Old Jun 6, 2012 | 09:34 PM
olstyn's Avatar
My stock 1.8T maxes out at 11 PSI, and it only does that if I floor it in a high gear at low RPM (driving more "normally," like flooring it in a lower gear, I'll see 9 PSI max). My understanding is that Stage 1 maxes at around 15-16 PSI and 1+ is another few pounds, so 20 wouldn't be out of the question.
It's also possible that the OP's boost gauge is not 100% accurate - it might be reading a pound or two high, for example, which would put it right where it's supposed to be with APR 1+.
Old Jun 6, 2012 | 09:47 PM
to4xxx's Avatar
Its got 140k miles...so 20 is normal?
Old Jun 8, 2012 | 11:40 AM
OOOOk's Avatar
Did you not ask any questions before getting tuned?? Yes 20 is a little on the high side, you are probably around 16-18 psi peak with the tune. Your AutoZone boost gauge is probably a little off. However 20psi peak isnt out of the question. I have stage 1 tune done on mine and it peaks around 19 and levels off around 13.
Old Jun 8, 2012 | 11:56 AM
pa4ul's Avatar
yea ive heard the most accurate boost gauges are digital ones. So that might be part of the reading problem. . . .
M3Armand
Jan 4, 2011 12:04 PM
Soley4pres
Jan 31, 2007 04:08 AM
fenderstrat1184
Dec 21, 2006 02:35 AM
a4bsix
Jul 6, 2006 04:28 PM
s4me
May 18, 2005 08:39 PM
