k04 turbo upgrade, worth it?
Old Jun 21, 2011 | 03:22 PM
aud1's Avatar
Default k04 turbo upgrade, worth it?
so i've got an 04 1.8t quattro(lovin it), with about 100k miles on it, and have been considering upping performance a bit. from what i've read and seen, the turbo upgrade gives a pretty significant increase in gains.
so my question is the k04 turbo upgrade worth it, and will my engine be able to handle the strain of the extra power? is there anything i can do to prevent it anddo i absolutely need to chip it?
any advice would be awesome!
Old Jun 21, 2011 | 09:21 PM
ImTheDevil's Avatar
You can put a k04 on with nothing else changed and use it. It'll be transparent. If you get supporting mods (DV, intercooler, chip) you'll make probably 30hp more than you would with a k03 and those mods. If you are going to upgrade the turbo, do it right with a GT series or a 2871r elim setup. Then you'll see real gains.
Old Jun 22, 2011 | 01:40 AM
olstyn's Avatar
Yeah, my thought is that if my stock K03 ever bites it, a K04 is only slightly more expensive, so it'll be a "might as well" kind of upgrade, but if I'm ever *really* on a mission for more power, I'll go bigger.
Old Jun 22, 2011 | 09:35 AM
spools's Avatar
I am in the same boat. My K03 bit the dust and I am looking to do the K04. My issue is I do not have the funds right now for the chip, fmic, DV etc etc so I plan to just slap a K04 turbo on it and add the others as I get the funds..
Old Jun 28, 2011 | 10:22 AM
mafrank83's Avatar
I wouldnt upgrade to a FMIC or the larger turbo unless you have lighter flywheel personally. Youre just going to have increased turbo lag and you are going to hate that even more. Upgrade your hoses, chip and exhaust first, then replace the flywheel and have at the turbo and FMIC upgrade after. Im still running my k03 and love the quick spool. And my stage 1 APR chip is putting down 19 psi at peak, and trimming off at about 16 psi, and I love the get up and go. Just dont slap a bigger turbo on without doing your research on the other goodies.
Old Jun 29, 2011 | 07:10 PM
aud1's Avatar
yea I just replaced the flywheel recently actually, but I guess my thing is that I don't want to put too much strain on the engine and have other **** breaking as a sacrifice for hp and end up spending more on repairs than mods, you kno? and i don't want to always have to take it easy on the engine and not push it, it kind of defeats the purpose
at any rate does apr's chip software raise any illegality or lead to my engine getting degraded, at least more quickly?
Old Jun 30, 2011 | 03:02 AM
audiaubrey's Avatar
hey fellas!! so my turbo just went out!! IM THE DEVIL: any suggestions for websites or stores for specific turbos?? i was thinking k04 as well since i do not know where to get another turbo with the correct set up.. i guess the 1st thing ya gotta do is LOOK AT IT!! right right right. im about to pull it out tomorrow and get on the way..so any suggestions or input would be greatly appreciated!! probably already at stage 3 with mods..
Old Jun 30, 2011 | 03:13 AM
audiaubrey's Avatar
oh. and whats the best turbo for a 1.8 t engine code ATC... i checked out the 2871r elim setup but it wont fit the 180hp model :/
kakluote
Dec 5, 2012 04:06 AM
to4xxx
May 19, 2012 08:34 PM
.:FMD
Feb 5, 2011 06:38 PM
5Speedwtneed
Nov 2, 2010 10:44 AM
audiholix
Oct 21, 2007 02:46 PM
