Left Dipped Headlight
Ok I pretty much figured my main question, which was, what is the stock temp. Saw in another thread that its 4500k.
My left light isn't coming on and I just tried to pull out the bulb to switch it with the right, to make sure if I needed a new one. First thing I noticed was mine are 8000k. Then I figured out how to get the bulb out. My problem now is the bulb won't come off the harness. So, I can't switch them! I don't know if I'm not pulling hard enough or those things are stuck, but I'm pulling enough to where I can hear the bulb sounds like it's cracking.
I'm guessing the previous owner installed HIDs
Sorry if the pic isn't good quality but that's the best I could do since its night.
Correct me if I'm wrong, but can I just get another H7 HID (and harness if I can't pull the bulb)???
These are aftermarket HID bulbs and they will NOT come off. They are glued into the socket (black one in your hand) and the wires run into a connector. That's where you need to disconnect them, they have a tab. Not sure of you can get the same connector with another HID kit, but most of them look like they use the same connector.
https://encrypted-tbn2.gstatic.com/i...16iJUWm80jE-iQ
or
https://encrypted-tbn3.gstatic.com/i...TMF5Xi4emSTZ7L
or
http://vleds.files.wordpress.com/2010/12/h11_hid1.jpg
Good luck.
FrankEGD
or
or
Good luck.
FrankEGD
Thanks man. I've been stumped for a while. I figured it out when I kept looking for bulbs and most of them came with wires. I was on the verge of freaking out and just buying a new kit.
Ended up seeing the watts also. Didn't notice it was on the other side of the sticker that was next to the bulb. I actually tried opened up the ballast to see if it had any markings for me hahaha
