Misfiring cylinder 1... PLEASE HELP
Old Jun 6, 2014 | 06:33 PM
Drew.young1980's Avatar
Default Misfiring cylinder 1... PLEASE HELP
Okay so here is the scenario. I have 2002 a4 3.0 Quattro 6 speed. I was driving on the freeway today and check engine started to flash and car sputtered. Pulled over immediately. Scanned for codes and had a misfire in 1, 4 and 6. So I swapped coil packs, cleared codes and checked again. Now misfire 1 & 2' this time swapped the remainder of the coil packs and new plugs. Now only have misfire in cylinder 1. Swapped coil pack with 3 and still cylinder 1. Buddy at local european shop said possible burnt valve or low clearance valve. PLEASE ANY HELP WOULD BE GREATLY APPRECIATED.
Old Jun 6, 2014 | 10:18 PM
JDJ's Avatar
JDJ
I would try swapping or replacing your spark plugs and looking at your coil pack wiring harness, looking for frayed or broken wires, before looking into valve problems.
Old Jun 7, 2014 | 12:15 AM
Default Update
I swapped plugs and coil packs. Still misfire cylinder 1. Going to try new MAF sensor tomorrow and an OEM coil pack on cylinder 1. Checked harnesses and all looks good.
Old Feb 17, 2017 | 01:45 PM
Audiguyb7's Avatar
Default HELP MY 2006 Audi a4 2.0t is misfiring.
I started getting the code P0301. I changed my spark plugs and the first amd second cylinder coils. and the code still comes. I start the car cold and it sputters for a while and then goes normal. I also did my oil change about two weeks ago. and i used synthetic 5w30. i hope thats okay for the car. would anyone have a idea.
Old Jul 27, 2017 | 11:32 PM
Llwyd C. Joseph's Avatar
Default Any new news on this situation?
Old Jul 27, 2017 | 11:33 PM
Default Please reply asap
im having the same problem, any news on fixing it ?
Drew.young1980
Jun 6, 2014 06:37 PM
wmccann
Apr 14, 2014 03:52 PM
dmk11
Aug 7, 2009 06:43 PM
dmayer75
Nov 17, 2007 09:02 PM
rabthol
May 19, 2005 12:26 PM
