misfiring cylinder
misfiring cylinder
i have an 02 3.0L A6 that's misfiring on cylinder 5. i also have a bad O2 sensor. is the misfiring related to the sensor? if so, can the misfire be fixed without replacing the O2 sensor right away. any suggestions? thanks!
RE: misfiring cylinder
yes you don't have to replace the 02...unless you have a code for a bad 02 you are fine there. also as long as the 02 is not one of the primary 02's there would not be a issue with misfires....02's can some times lead to misfires but in the end you should look at the coil and then the plug as well if the misfire still is there you may also have a bad MAF....
i do have a code for a bad O2 sensor, it's P0050 HO2S Bank 2 Sen 1. i'm not sure if this is one of the primary O2's or not. would this bad sensor have anything to do with my misfire? if so, is it worth trying to fix the misfire first? also, how difficult is it to replace the coil? thanks!
