Multiple headlight problems
Old Dec 20, 2008 | 01:26 PM
outlawz2323's Avatar
Default Multiple headlight problems
Hey guys, sorry if this is a double post.
I'm a newbie with a 2002 A4. I'm having a bunch of problems with my external lights. First I had the "right rear light" warning. I checked the lights, and they were all working fine. Then I got the "right front turn signal" and the right turn signal stopped working. about a week later, it started working again. Then, I got the "left dipped headlight", "right rear light" and "left rear light" warning and my driver side low beam is out. So I have 3 warnings and only one light out. Should I just replace the headlight that is not working, or is there a bigger electrical problem that I need to look into??
Also, I saw a thread that detailed how to change headlights and taillights on this forum, but I cannot seem to find it anymore. If someone could please help me out here, that would eb great.
Thank You.
Old Dec 20, 2008 | 03:13 PM
Myst420's Avatar
You may want to check the connectors to make sure they aren't corroded. The easiest way to change the headlights is to remove the whole housing. If you go to www.a4mods.com and choose the clear corner mod under "exterior and cosmetic" it will show you how to do so. For the taillights, all you have to do is remove the one screw from inside the trunk to take them out. You will see a small circle that you can pull out to reveil the screw.
Old Dec 21, 2008 | 07:34 PM
Thanks, went to the site followed the DIY and fixed my problems!!
OriginalChuckyFinster
Jan 2, 2015 03:02 AM
newquay7
Sep 30, 2014 01:36 PM
Bayleybeee
Aug 12, 2011 02:37 PM
ender9492
Mar 1, 2008 09:10 PM
pec2402
Dec 13, 2006 02:10 AM
