my car vibrates like a mo fo
Old Mar 26, 2008 | 02:25 PM
kakashisan's Avatar
Default my car vibrates like a mo fo
i have a 2004 1.8t a4 , and suddently start it to vibrate alot every time i press the gas pedal starts to vibrate the whole car, but when increase the speed to 70 and over stops most of the vibration anyone can help me thanks!!![>:]
Old Mar 26, 2008 | 02:52 PM
amiller86's Avatar
Default RE: my car vibrates like a mo fo
So it's vibrating when you're driving? Cause if you're moving and notice alot of vibration it could a wheel/tire balancing issue. (although if that were it, you would probably still notice it somewhat above 70). If it's vibrating while it sits, but the engine is being reved, I'd check for a mis-fire maybe. When my car mis-fired it vibrated ALOT. You getting any CELs? You try pulling codes? Made any mods lately?
Old Mar 26, 2008 | 03:48 PM
auditurbo381's Avatar
+1
Old Mar 27, 2008 | 03:53 PM
BigAl 1.8t's Avatar
get the codes pulled..probably the coil packs sounds like the same thing that happend to me, i changed the coil packs and problem solved..
Old Mar 28, 2008 | 12:09 AM
Mykull44's Avatar
If u change the Coilpacks, make sure you buy 4 brand new ones. If you just change one, it'll put a different load on the others and cause them to fail.
Old Mar 30, 2008 | 07:11 PM
kakashisan's Avatar
i check the engine mounts and found out they were crack, didn't know that they were filled with oil so i guess i need to replace them and that might resolve the vibrations
horsecrazy8907
Jan 18, 2009 10:10 PM
kakashisan
Jan 16, 2008 05:22 PM
jonsaudi
Nov 20, 2007 01:39 PM
martrvp1
Jul 29, 2006 12:07 PM
ram
Apr 24, 2006 05:59 PM
