My TCM Was Repaired
Old Mar 28, 2011 | 05:30 AM
xiaokai's Avatar
Default My TCM Was Repaired
Hi
I had bought my FSI which had or developed the dreaded TCM issue at 60k miles.
Lucky I had purchased warranty with the car and it was repaired for £1400 by my warranty company. (Thank God)
Any Way I wish to review my fault codes to make sure everything is ok now.
These are the codes i had previously.
AFTER A NEW (REFURBISHED) TCM
And now using my own OBD2 cable and VCDS-Lite Version: Release 1.0
I get the following errors
Friday, 11 March 2011, 23:14:50:0
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8E1 910 018 A
Component: 2.0L R4/4V FSI G 0020
Coding: 0000000
Shop #: WSC 63351
8E0907807 A NOX 0303270002 002 3205
1 Fault Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01J-927-156.LBL
Controller: 8E0 910 155 G
Component: V30 01J 2.0 FSI RdW 3120
Coding: 0000001
Shop #: WSC 63351
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04279
Shop #: WSC 06435
1 Fault Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Could some one enlighten me on the error codes i have left which were read by my self after the fix
Old Mar 28, 2011 | 09:59 PM
auditech79's Avatar
I'll take a crack at it, but the euro models are much different than ours. Im going to guess this is a FWD CVT transmission?
The error code after the repair is a simple brake light switch, nothing major really. You need to pull the panel under the dash by the brake pedal, then look straight up in front of the brake pedal. There will be a little switch right in front of the pedal with a small connector on it. Remove the connector and turn the switch counter clockwise and pull it out of its bracket. Installing the new switch is actually the tough part. These switch are literal crap straight from the manufacturer, similiar to the quality of the ignition coils from Bremi. Pull the thimble all the way out before pushing it in, hold the brake pedal towards the driver's seat and attempt to install the switch in a clockwise fashion.
If the brake lights stay on or won't turn off pull the sensor out, pull the thimble out again and keep trying it until its working correctly.
It may even be possible the switch is broken right off the shelf, it wouldn't be the first time i've come across a crap switch thats never been used.
Old Mar 29, 2011 | 05:59 AM
xiaokai's Avatar
thanks auditech
il try to look around that area and give the switch a try my self if i get the courrage.
i wanted to know where it says
Coding: 0000001
Shop #: WSC 63351
i hope they didnt just clear the code lol
i dont think they did because they are very reputable company that did the TCM exchange. http://www.automaticgearbox.co.uk/
Just wondering why that section still shows up if theres no errors.
Old Mar 29, 2011 | 10:26 PM
auditech79's Avatar
Doing a broad scan brings up a log of ALL modules scanned, your log is actually very small. If you did one with a VAS 5052 it can take up to 20 minutes and have a log of 50 modules.
The brake light switch is nothing large to worry about, you may notice that the ABS kicks in at light braking pressures or the cruise control doesn't work. It won't cause any engine/transmission operating issues.
Looking at your scan everything is working fine, with the exception of the brake switch.
arij66
Aug 14, 2013 02:51 PM
hankeester
Jan 18, 2011 11:42 PM
02AudiA63L_65
Sep 18, 2010 10:30 AM
Boratio
Jul 24, 2010 11:49 AM
IWantAnA4
Mar 1, 2005 05:45 PM
