need to keep resetting ecu for chip?
Old Sep 8, 2012 | 07:38 PM
to4xxx's Avatar
Default need to keep resetting ecu for chip?
Hi,
I'm running into a problem where i have to reset the ecu every half day or so driving to keep my chip running. It is a 02 a4 cvt with apr stage1+ injectors and an aftermarket air intake with straight pipe exhaust.
With the chip running I boost about 18 to 20psi max. After a while it limits itself to 5.
Any thoughts? I hate disconnecting and reconnecting the battery do often just to get the performance I want.
Thanks
Old Sep 9, 2012 | 11:10 AM
olstyn's Avatar
Sounds like you're going into limp mode. That means the ECU thinks something is wrong. Pull some codes and do a google search. If you don't find the answer that way, come back here and post the codes and people will try to help you.
KpF2007
Aug 21, 2009 06:11 PM
kibs45
Jul 18, 2007 09:03 PM
AudiCross
May 9, 2007 09:08 PM
Flippa_s4
Sep 14, 2006 10:50 AM
smythe
Jun 3, 2005 09:12 AM
