New Audi A4 Owner 3.0 technical questions/advice
Old Feb 9, 2016 | 04:56 PM
keeko785's Avatar
Default New Audi A4 Owner 3.0 technical questions/advice
Vehicle is a 2003 audi a4 3.0 Liter 180k Miles
Ok to start off, I did a search on youtube and a search on this forum before posting.
1: Headlight washer won't activate. I followed a youtube video how to test, turn headlights on, turn brights on, activate washer. Did not work, neither popped up. Where to go next? Should I pull out and apply 20-25psi air to them to see if they pop up? Are these even worth fixing?
2: Heated washer fluid. I normally install these on all my vehicles, but I read this vehicle already has one. How do I test? Is there a reservoir that I can test temp in?
3: Dome light doesn't turn on when drivers door opens but does when all other doors open, with this broken the "headlights left on chime" doesn't work either. I have changed out door pins on older 90's pickups but they were extremely obvious. Where is it? Where can I test it ect.
4: headlights, are not automatic. Has anyone installed an auto headlight kit. I have installed these in the past made by Directed electronics(small sensor you mount on the dash and turns on headlights at dusk/off at dawn, does anyone have a better option that they have used?
5: Fuel. I have owned a 04 range rover for 9 years, always put 87 octane in it no problems. The owners manual recommends 91 octane or higher.
6: keys, I am probably going to permanently bypass the transponder chip in the key, might go keyless push button or might get a second key ordered. I found a company that you can send a picture to and they will make a new key blank for you, but in order to program another transponder(if I don't perm bypass transponder) does anyone have any recommendations?
7: Vehicle startup, I noticed a smell of exhaust at startup but goes away after driving about 100 yards or so. I am going to change out the cabin filter this week, but this should not be normal, I would say if I installed a carbon monoxide alarm in the car it would go off. Anywhere I should start besides door seals, and firewall seals ect..
8: Do these vehicles come standard with a block heater? I am located close to the canadian border and was wondering if these come stock or If I will need to have one installed?
Last edited by keeko785; Feb 12, 2016 at 12:08 PM. Reason: Added vehicle year and engine
Old Feb 12, 2016 | 12:07 PM
keeko785's Avatar
234 Views and 0 responses?
Should I move this thread to technical?
Old Feb 14, 2016 | 12:22 PM
keeko785's Avatar
Admins, you can lock this thread, I moved the question to a much more helpful website.
Old Feb 23, 2016 | 02:35 PM
georgesro's Avatar
Default Tec question
My A4 seems to have an iffy battery which I think is causing a very unusual fault! car fine to drive but when I turn it off it tells me everything is wrong and it makes a whining alarm sound even with the key out of the ignition. Put it back in and start up all goes to normal (OK) Turn off the same! Batt on charge now...any ideas?
zoe123
May 3, 2011 03:07 PM
robster34
May 20, 2008 04:32 PM
twinturbo_in
Mar 12, 2008 02:13 PM
CdnAudiNewbie
May 25, 2006 07:23 AM
Al_s14
Dec 27, 2005 11:29 PM
