new breather hoses 3.0
Old Dec 24, 2011 | 12:08 PM
audiA4thewin's Avatar
Talking new breather hoses 3.0
i need new breather hoses for my 3.0 and i cant find them anywhere! blau parts only supplies new ones for the 2.8 any help will be appreciated
Old Dec 25, 2011 | 12:24 AM
and the ones on ecs that i did happen to find didnt have the lower hoses unless the picture just didnt have them added and they are included. Audi B6 A4 Quattro V6 30v > Search > Breather > ES#280183 Breather Tube - Priced Each - 06C103217G
Old Dec 26, 2011 | 10:51 AM
jdahlen24's Avatar
You were close.
Go to this link at ECS, and you'll see that there are three different PCV service kits depending upon your VIN.
Old Dec 27, 2011 | 08:38 AM
StevieB67's Avatar
I had to buy the lower hose separately. I needed this but you may need this other one depending on your VIN.
Old Dec 28, 2011 | 11:06 AM
thanks for all the links and help guys. is there a link you can give me that has a write up about how to remove the hoses properly? they are pretty fragile from what i remember.
Old Dec 28, 2011 | 11:09 AM
this sounds pretty simple but is the vin right on the pcv valve? or is it on each hose?
Old Dec 29, 2011 | 08:57 AM
jdahlen24's Avatar
The VIN is your Vehicle Identification Number, which can be found just above the driver's side windshield wiper as you look through the windshield from the outside in. You could actually call ECS Tuning and give them your VIN and they should be able to get you all the hoses you'll need.
I couldn't find a DIY on replacing these on the 3.0, so maybe you could take your time and be the first person to post a DIY on how to do this.
Just be very, very careful when replacing these hoses because they don't "give" at all. Do not try to bend them to get that last 1/4" distance.
I haven't taken the time on my B6 to see how much of a PITA this job will be, but I replaced the entire crankcase breather system on my B5 with the 2.8, and that was about a 9/10 on the PITA scale. But, I was able to get it done and I saved myself multiple hundreds of dollars in labor.
Good luck!
Old Jan 1, 2012 | 06:58 PM
oh haha thanks for the clarification! and yeah ill do pics and everything when i do it!
Old Jan 2, 2012 | 07:40 AM
StevieB67's Avatar
Just as a heads up... I wasn't planning on replacing the lower hose BUT I broke it (by looking at it ) and had to remove the throttle body to get access to the bottom connection. So you might as well get a can of throttle body cleaner and clean it while you have it out.
Old Jan 2, 2012 | 07:43 AM
sathibob's Avatar
Audi Breather Hose - Audi Crankcase Breather Hoses
dude chk out this link and u can buy asap if u have any doubt pls do contact k ... happy new year hae a nice day
