New coilpacks & spark plugs!!! NEED Help
Old Apr 13, 2008 | 04:33 PM
Baseballpler's Avatar
Default New coilpacks & spark plugs!!! NEED Help
So I got my car flashed with revo software a few months back and I never switched out the coil packs and plugs like I heard most people do to maximize the performance. I have felt my car hesitate many times and i figured it was time to buy some new ones. Just ordered the Oem revision "R" and the ngk plugs that a step cooler from ecstuning. I was just curious as to how hard it was to replace these things and what tools I would need. I know I need to gap the plugs to .028, I do most of the stuff to my car myself but this is one thing I wanna do right the first time, any help would be sweet... Thanks
Old Apr 13, 2008 | 05:23 PM
amiller86's Avatar
Default RE: New coilpacks & spark plugs!!! NEED Help
All you need is a flathead screwdriver to release the wiring harness from the coils. Then use it to gentley pry up the coils from their holes. It's pretty easy. Then of course you'll need a spark plug socket, and an extension to remove the plugs. To gap the plugs you'll need a gapping tool... Oh make sure you torque your plugs back to spec (you should check exactly what your car calls for) otherwise they can loosen, and cause other problems.
Old Apr 13, 2008 | 05:25 PM
auditech79's Avatar
Changing plugs and coils is probably the easiest thing your ever gonna do to your 1.8T.
Just take off the engine cover, dis-connect the harness to the coils and pull the coils out. Use a 5/8 spark plug socket (or metric if you have it) and pull out the plugs. Gap the new ones and hand tighten them in. Tighten the new plugs to about 40NM, or 20ft lbs.
Pop the new coils on and your good to go.
Old Apr 13, 2008 | 08:08 PM
bronxblaza117's Avatar
you need to gap brand new plugs?
Old Apr 13, 2008 | 08:12 PM
adotjdot's Avatar
yeah i am about to do the same thing because i just got new software. the only thing i dont understand is how to know how much to tighten it. how do you know how much 30nm is?
Old Apr 13, 2008 | 08:38 PM
amiller86's Avatar
use a torque wrench
Oh and you should always atleast check new plugs.. It takes like 60 sec. to check all four, so why not do it?
cheesy44
Apr 19, 2010 07:34 AM
Bigrigatoni
Aug 1, 2008 12:16 AM
harryd14
B7 Models
Jun 1, 2008 04:38 PM
Dj Spiel
Sep 15, 2006 07:29 PM
