Oil Pressure Low - light
Now I have read quite a few posts here saying usually low oil pressure light means sludge, most B6 models are generally known to burn oil and thus frequent top-ups. When people comment with reference to sludge they should precisely point out that if the dip stick indicates acceptable level of oil then query sludge. How can I even dream of sludge if the dipstik says low? Even without a leak in most B6s oil gets low. The issue of low oil pressure is confusing enough on its won without pple generalising like that.
Haha your post is funny. Ok, just because the level is low doesnt mean that you will be having low pressure. Also, my car hasn't always burned oil. Lately I've been going through about a quart every 10k miles, which I blame on high miles or maybe a bad head gasket or something. But, even when my low oil level light comes on and the oil is just barely on the dipstick I still dont have low oil pressure.
yeah ive never had to add a drop to my car as long as ive owned it.and to your question-low oil level shouldnt trigger a low oil pressure light
the 2.0t B7s or anything with direct injection will burn a bit between changes.
Huh......................?
Low oil level not trigger low oil pressure...........?
Where do you think it gets the pressure from.......?
1 qt to 1,000 miles is Audi spec for consumption. I know its alot. They are saying its safe to be adding 5 qts between oil changes which is ridiculous and obviously on the extreme end.
Thats a lot of oil. I would look for a leak. Look at the head gasket and valve cover gasket.
