oil problem
Old Apr 13, 2010 | 09:46 AM
perdoms's Avatar
Default oil problem
my car looses about 1.5 quarts of oil a week. when lookin at the engine from the front there is some oil on the right side of the engine. i cant see where it comes from and audi cant figure it out either because everytime i bring it there the problem magically dissapears. any thoughts and also is there an over flow hose for the oil if you put too much in???
Old Apr 13, 2010 | 10:35 AM
esandes's Avatar
Banned
i think there was a bulletin for a fix of a vent hose (?) or something like that. take it to the dealer for a check and possible free fix.
Old Apr 13, 2010 | 10:54 AM
shane.trammell's Avatar
On the right side could be related to the filter. Does the filter have oil on the outside?
Old Apr 13, 2010 | 11:31 AM
perdoms's Avatar
audi told me the first time i took it there that the oil filter was put in a little crooked ( witch they installed earlier) and said some oil was leaking from it and they put it back on and i still have the problem. audi also replaced the valve cover gasket because they thought it might have been that but its not that either
Old Apr 13, 2010 | 12:00 PM
If the filter was crooked they probably cross-threaded the filter mount.
Old Apr 13, 2010 | 07:20 PM
Dan1969's Avatar
If you have smoke coming out the back is more than likely your head gasket, not the valve cover gasket. Also before doing that have the PCV replaced, they can cause oil loss. Keep an eye on the oil until you have your problem figured out, and don't top it off with any oil, use full synthetic...
On the upside you have constantly fresh oil...
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
